Date/Time: Sun, 09 Mar 2025 13:22:15 +0000
Moving chart
View Count: 1776
[2019-06-28 14:34:17] |
User731023 - Posts: 143 |
I use to be able to move chart with hold Ctrl and left mouse. Even with Lock Fill Space checked, before recent download. Can't do it anymore. Is there another way without un-checking the Lock Fill Space? Thank you |
[2019-06-28 14:43:18] |
You can reverse the state of Lock Fill Space with the Control key but you need to actually adjust the fill space with scroll bar at the bottom of the chart or the arrow keys on the keyboard.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-28 14:43:38
[2019-06-28 15:11:25] |
As you probably know you use to be able to move it when you had the hand checked with the Ctrl and left mouse on the chart. This was a nice feature to do it quickly and you could also adjust the up/down scale at the same time. Live long and prosper. |
[2022-03-06 15:13:32] |
USER333 - Posts: 2 |
Please at least give us the option to toggle lock space with ctrl key while using hand tool. This function has been there for as long as I can remember. It's very convenient and intuitive. At some point during 2019 I realized this is no longer working but I didn't pay much attention. Now I'm back heavily rely on Sierra and need this function, it's very frustrating that an old fundamental interaction just not there anymore for no apparent reason. |
