Date/Time: Sat, 01 Feb 2025 06:51:48 +0000
Chart with associated watch list
View Count: 742
[2019-06-28 09:07:51]
User834905 - Posts: 35
Is it possible to have volume profiles (and other drawings) made specific to the chart instrument?
For example, if I have a chart with an associated watch list, for symbols A, and B and I draw a profile on A, can that profile be made specific to symbol A, so I do not see it on the chart when symbol B is selected?
[2019-06-28 13:42:58]
Yes. Refer to:
Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols (Showing or Hiding Chart Drawings for Different Symbols)
[2019-06-30 11:17:02]
That worked for most drawings.
However, the volume profile remains on the chart.
The actual profile is hidden but the VAL, VAH, and POC lines remain visible.
I previously created a number of 'Tool Configs' based on studies and use buttons to select the desired Volume Profile Tool (VPT).
When I now select the VPT it uses the last tool config and this results in a study being added to the chart.
Maybe that is the problem, as I don't know how to revert back to the default VPT settings?
[2019-07-02 20:34:45]
This will be resolved in the next release.
Yes this will be the case. A Volume by Price study is going to be added to the chart for each instance of the use of the Draw Volume Profile tool.
Make sure you are using this functionality:
Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step
Date Time Of Last Edit: 2019-07-02 20:35:28
