Date/Time: Mon, 24 Feb 2025 03:26:26 +0000
copy from SCH to Metatrader 4,5
View Count: 3381
[2019-06-28 08:52:40]
User245469 - Posts: 6
Good day!
I trade with you through the Sierra Chart platform and got into a project where I can get a capital from an investor. I have to go through two months of paper trading test and meet their conditions. The problem is that they only use Metatrader 4, Metatrader 5 and cTrader platforms.
They also used Ninja trader 7 and had a program that copied business orders to their Metatredra 4.5 platform and they could control your money management and results.
But with the release of the new version of Ninja Trader 8, it started to show some bugs and they stopped providing NT7.
For my daytrading i need tick data and that
metatreder doesnt have.
That's why I wanted to ask if you know about some copying program to solve it. From Sierra Chart to metatrader.
Or if you dont know of any solution
thank you very much with greeting Pavel Hunger
[2019-06-28 09:28:16]
ganz - Posts: 1048
User245469
i need tick data and that metatreder doesnt have.
https://www.mql5.com/en/docs/series/copyticks
Intraday Data File Format: Data Structures Used
Python for Sierra Chart
Date Time Of Last Edit: 2019-06-28 09:29:10
[2019-06-28 15:34:15]
If we were to support CTrader FIX would that solve the problem?
Reference:
https://help.ctrader.com/fix
Date Time Of Last Edit: 2019-06-28 15:34:34
[2019-06-28 16:53:37]
Thanks for the answer, maybe it could be a solution.
Just read your link. the project uses Metatrader 4 and 5 platforms as well as cTrader. what I would need is that I order the Sierra Chart orders and they would also be immediately filled in the c trader. Think it would be possible?
if we solve it, you are the best !!! :-)
Thank you, best regards, Pavel
[2019-06-29 06:19:18]
User871277 - Posts: 34
Support of c-Trader would be great.
[2019-07-02 13:40:27]
Good day, please and you know how to insert this command? Or how to do it? thanks Pavel
[2021-03-02 22:35:10]
User888583 - Posts: 20
Hey! Many people have this problem.
I create a tool, that allows copy trades from Sierra Chart to MT4/MT5 (and other platforms in the future).
Integration is easy - just connect Study to the symbol you want to copy over, and EA on MT4 to receive the trades.
Everything can be configured using admin panel. In future I might consider enable DTC protocol, to have even better integration with Sierra Chart.
https://aimfx.io/
Feel free to test it out.
Cheers,
Lukasz
