Date/Time: Sat, 01 Feb 2025 09:55:43 +0000
Data missing from Bitfinex. BSVUSD-Bitfinex, EOSUSD-Bitfinex
View Count: 1503
[2019-06-28 07:26:03]
User960746 - Posts: 25
I have been using sierra chart for one year, it's great and help me a lot. Thanks for your effort on it.
Since yesterday, the chart of EOSUSD-Bitfinex in SierraChart does not update. But charts of BTCUSD-bitfinex, ETHUSD-bitfinex update correctly.
However, the App AICOIN in my Android phone shows the EOSUSD-Bitfinex update correctly. So the data feed from Bitfinex should be OK.
Another problem is the BSVUSD-Bitfinex always loads no data and shows a blank chart in SierraChart, but the App AICOIN shows the BSVUSD-Bitfinex correctly.
Could you help me with these two problems?
Thank you so much.
Date Time Of Last Edit: 2019-06-28 16:42:49
[2019-07-01 20:33:47]
This is involved for us to resolve. We are not sure when we can get to this.
[2019-07-02 02:54:59]
Thanks for your reply. We (cryptocurrency traders) really appreciate your help. Do you consider supporting more data sources, such as OKEX and BINANCE?
Thank you.
[2019-07-05 12:47:39]
I noticed that the price of EOSUSD-Bitfinex updates on real-time, but the bar chart is different from other data sources.
