Date/Time: Sat, 01 Feb 2025 06:49:37 +0000
How to add horizontal lines/colors on my chart
View Count: 1167
[2019-06-28 05:47:12] |
daniel1950 - Posts: 13 |
Hello. I saw this chart on twitter and am wondering how I can visually color rectangular boxes for support/resistance/balance areas. I've attached the chart.
Attachment Deleted. |
[2019-06-28 14:15:40] |
You can do this using the Rectangle drawing tool: Chart Drawing Tools: Rectangle | Extending Rectangle | Ellipse | Triangle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
