Date/Time: Sat, 01 Feb 2025 06:51:24 +0000
Unable to login to Rithimic/OneUp trader otc bridge
View Count: 1308
[2019-06-27 15:38:50] |
User805846 - Posts: 6 |
Unable to log in plz help, keeps disconnecting, Rithmic Trading | Port for executable: 53826 | 2019-06-27 13:39:31.138 Listening socket (2296). Port 53826 | Closed. | 2019-06-27 13:39:31.138 Rithmic Trading | Starting server: C:\SierraChart2\Rim\DTCBridge.exe | 2019-06-27 13:39:31.141 Created process C:\SierraChart2\Rim\DTCBridge.exe. Parameters: /Port:53826. Current folder: C:\SierraChart2\Rim | 2019-06-27 13:39:31.223 Rithmic Trading | Bridge process is not running! | 2019-06-27 13:39:33.325 Rithmic Trading | Connecting to the server 127.0.0.1. Port 53826 | 2019-06-27 13:39:33.325 DTC Client socket (2) | Creating socket. | 2019-06-27 13:39:33.325 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2019-06-27 13:39:33.325 DTC Client socket (2) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-27 13:39:34.327 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-27 13:39:34.371 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-27 13:39:34.371 DTC Client socket (2) | Closed. | 2019-06-27 13:39:34.371 Rithmic Trading | Disconnected. | 2019-06-27 13:39:34.377 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-27 13:39:34.377 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2019-06-27 13:39:34.447 The message log has been sent to support. | 2019-06-27 13:39:34.447 * HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Connecting to IP: 46.4.97.203. | 2019-06-27 13:39:34.447 Sending of the Message Log is completed. The response was saved to C:\SierraChart2\Data\MessageLogAnalysis.htm | 2019-06-27 13:39:35.439 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Shutdown started. Waiting for graceful close. | 2019-06-27 13:39:35.975 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2019-06-27 13:39:36.003 HTTPS connection ID:3 to www.sierrachart.com:443 for request ID:3 (2) | Closed. | 2019-06-27 13:39:36.004 Rithmic Trading | Port for executable: 53831 | 2019-06-27 13:39:36.499 Listening socket (2232). Port 53831 | Closed. | 2019-06-27 13:39:36.500 Rithmic Trading | Starting server: C:\SierraChart2\Rim\DTCBridge.exe | 2019-06-27 13:39:36.503 Created process C:\SierraChart2\Rim\DTCBridge.exe. Parameters: /Port:53831. Current folder: C:\SierraChart2\Rim | 2019-06-27 13:39:36.631 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-06-27 13:39:38.584 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2019-06-27 13:39:38.584 DTC Client socket (1) | Closed. | 2019-06-27 13:39:38.584 Rithmic Trading | Bridge process is not running! | 2019-06-27 13:39:38.626 Rithmic Trading | Connecting to the server 127.0.0.1. Port 53831 | 2019-06-27 13:39:38.626 DTC Client socket (1) | Creating socket. | 2019-06-27 13:39:38.626 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2019-06-27 13:39:38.626 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2019-06-27 13:39:39.630 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-06-27 13:39:39.630 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-27 13:39:39.630 DTC Client socket (1) | Closed. | 2019-06-27 13:39:39.630 Rithmic Trading | Disconnected. | 2019-06-27 13:39:39.641 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-06-27 13:39:39.641 File >> Disconnect selected. | 2019-06-27 13:39:40.940 Rithmic Trading | Disconnected. | 2019-06-27 13:39:40.941 The message log has been sent to support. | 2019-06-27 13:40:41.650 * HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Creating socket. Using TLS 1.2. | 2019-06-27 13:40:41.650 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Connecting to IP: 46.4.97.203. | 2019-06-27 13:40:41.651 Sending of the Message Log is completed. The response was saved to C:\SierraChart2\Data\MessageLogAnalysis.htm | 2019-06-27 13:40:42.459 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Shutdown started. Waiting for graceful close. | 2019-06-27 13:40:42.952 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Socket gracefully closed by remote side. | 2019-06-27 13:40:42.981 HTTPS connection ID:4 to www.sierrachart.com:443 for request ID:4 (1) | Closed. | 2019-06-27 13:40:42.981 |
[2019-06-28 14:10:03] |
You need to have your own direct account to connect to Rithmic through One up Trader: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
