Date/Time: Fri, 07 Feb 2025 15:05:30 +0000
List of all chart drawing alerts ?
View Count: 1644
[2019-06-27 13:02:01]
TedMar - Posts: 190
How i can find all drawing alerts active for symbol/subgraphs or for all symbols/subgraphs?
Window> Alert Manager is empty if i set drawing alert in subgraph.
[2019-06-27 15:22:33]
The only way is if an Alert Condition Formula is true and that can be viewed through the Study Summary:
Study Summary Window
We suppose we could add some kind of an indicator to the study name like [A] in the Study Summary to indicate if it has a defined alert condition.
Are you referring to studies or Drawing Tool drawings?
Date Time Of Last Edit: 2019-06-27 15:23:47
[2019-06-27 22:00:00]
TedMar - Posts: 190
Drawing Tool, in Example a Horizontal Line in a study with an alert.
if not posible list Drawing tool alerts for symbol/studies in a Window , mybe is an idea set a Jingle Bells symbol @ Drawing tool with enabled alert? or an other any info..
[2019-06-30 01:16:05]
Have a look at the Manage Chart Drawings window:
Chart Drawing Tools: Manage Chart Drawings
It has the ability to filter the list of drawings by those that have alerts.
Date Time Of Last Edit: 2019-06-30 01:17:39
[2020-06-07 14:55:23]
skelcap - Posts: 139
It would be useful to have a way to view all Chart Drawing Alerts for a particular symbol from across multiple charts (not just the Manage Chart Drawings window for one chart). E.g. I might have a resistance line for a symbol marked on a couple of charts on one chartbook and also in another chartbook. I might have set alerts for each of the lines at different times. When the alert is triggered I only want to receive one alert, but I can't easily figure out where I've duplicated the alert except by going through each chart and clicking on the lines or viewing the chart drawings window, which is cumbersome.
[2020-06-07 15:08:51]
I guess what I'm really looking for is a fully integrated alert manager, which shows all alerts (symbol alerts, study alerts, drawing alerts) for all symbols in all open chartbooks.
[2020-06-08 02:13:44]
Refer to:
Alerts Manager: Disabling Alert Sounds
Would be best that you just use Chart and Study Alerts:
Study/Chart Alerts And Scanning
And monitor them through the Study Summary window:
