Date/Time: Sat, 01 Feb 2025 06:49:38 +0000
[Programming Help] - Delta Divergence Alert Formula
View Count: 3157
[2019-06-26 19:33:16] |
User929084 - Posts: 60 |
Hi. I'm trying to get signal when there is divergence between price and cumulative delta. Where the price bar closes up and delta closes negative and when price bar closes down and delta closes positive. I'm trying to get simple alert with study "Color bar based on alert condition". When I use this formula =AND(C<O,ID1.SG4>0) on ask/bid volume difference bars study it works fine. Where ID1 is ask/bid volume difference bars But when I use the same formula =AND(C<O,ID1.SG4>0) on cumulative delta bars- volume study it gives me signal on every price bar that closes down. Can this be accomplished with cumulative delta bars study by modifying this formula? I would like to get this done on cumulative delta, because I use it. And I do not use ask/bid volume difference bars. P.S. I found posts about the same thing, but no formula examples were provided, just custom studies that accomplish the same thing. And I would like to avoid that if I can. Thank you. |
[2019-06-27 13:21:48] |
User657944 - Posts: 173 |
I suggest you to register and post your request on this forum http://forum.obchodni-indikatory.cz/forum/ke-sta%C5%BEen%C3%AD And see how they can help you Alberto Date Time Of Last Edit: 2019-06-27 13:22:14
[2019-06-27 20:04:57] |
mkata - Posts: 103 |
On cumulative delta bars you are measuring against the open of the bar not zero. It should be: =AND(C<O,ID1.SG4>ID1.SG1) |
[2019-06-28 03:36:40] |
I figured it out today, but thank you for your help mkata.
