Date/Time: Sat, 01 Feb 2025 06:57:44 +0000
Fibonacci Fan Tool - Adding additional digits after separator (comma)
View Count: 1755
[2019-06-26 18:08:32] |
REKT4K - Posts: 8 |
Good day. By default the Fibonacci Fan Tool only allows to draw levels with two digits after comma i.e. "1.01", it doesn't allow inputs with 3 digits and more. Are there some settings or adjustments with Sierra settings to unlock additional digits? I need levels with at least 4 digits after comma for my calculation purposes i.e. "1.0001". To be more specific, I need to use inta-levels between main speed resistance levels. So, to put an internal retracement level, I need to use a value of "13.2252" - Sierra is rounding it to "13.22", but it is too low, while "13.23" it too high. And if you were using a Fan to build retracement levels for a big period of time i.e. 7-8 years of price movement, then all future levels are becoming highly inaccurate. I can tell that for sure as I'm using charts from TradingView for a comparison, and those 2 extra digits do matter whether price is touching them or not. Thx in advance. Date Time Of Last Edit: 2019-06-26 18:38:45
[2019-07-01 20:19:59] |
This will be supported in the next release.. The precise value that you are entering now is saved. It is only when you reopen the Tool Configuration dialog that you see the fractional part rounded to two decimal places. We will increase to 4. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
