Date/Time: Sun, 24 Nov 2024 19:36:10 +0000
Retracement tool in ACSIL
View Count: 1260
[2013-12-01 14:45:36] |
flyboy615 - Posts: 56 |
Hi, Is there a way to identify the tool configuration to use when adding the retracement tool via a study? What I want to do is to pick up the levels, Viability and color already defined by the user and not add all these items via inputs. Thanks |
[2013-12-01 19:55:20] |
This is not supported.
[2013-12-01 20:07:08] |
What about a way to limit the length of the line when the extend right is used, something like the "Extend multiplier" in the tool configuration? Thanks |
