Date/Time: Sun, 24 Nov 2024 18:24:25 +0000
Numbers bars feature request
View Count: 1794
[2013-12-01 10:56:06]
User14289 - Posts: 2
It is possible to add feature to display candles over numbers bars , See attached screenshot. It comes from OFA plugin for Ninja, but it is perfect solution to use one chart instead of two.
Thanks.
imageSnímek obrazovky 2013-12-01 v 11.54.29.png / V - Attached On 2013-12-01 10:55:25 UTC - Size: 118.01 KB - 494 views
[2013-12-01 11:04:40]
ganz - Posts: 1048
User14289
FYI: https://www.bigmiketrading.com/sierra-chart/29007-ofa-sierra-chart.html
[2013-12-02 19:21:18]
User GDAC - Posts: 62
This can also be done using the 'Çurrent Price Line' study. Simply add to a numbers bar chart, select 'Color Bar' draw style (or Color Bar Hollow). This will draw a candle over the numbers bars.
See: http://www.sierrachart.com/image.php?l=1386012049853.png
[2013-12-02 19:48:06]
Thanks, but integrated feature will be perfect. Sierra team ?
