Date/Time: Sat, 01 Feb 2025 04:05:25 +0000
Include orders in spreadsheet
View Count: 637
[2019-06-25 08:23:04] |
esc! - Posts: 15 |
Is it possibly to include a list of a all my open (limit) orders in a spreadsheet? Background: I would like to calculate the approximate liquidation price when averaging dowm/up on Bitmex. BTW just started using SC with Bitmex some weeks ago and it's really a great tool! Good work! |
[2019-06-25 14:23:56] |
This is not supported with spreadsheets. You will need to use ACSIL to access the orders: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
