Date/Time: Sun, 24 Nov 2024 18:23:40 +0000
Placement of Horizontal Line at Precise Price
View Count: 1410
[2013-11-30 22:41:20]
ged - Posts: 233
I would like to be able to draw a horizontal line and know the exact price level it is at as I drag the line on the chart. I can do this using the Chart Calculator Tool, but when I drop the line into place, the Chart Calculator tool places unwanted text information on the chart. I haven't been able to find a way to prevent Chart Calculator text from appearing, or, in the alternative, another way to accomplish placing the line with precise price information.
[2013-12-02 21:39:04]
ged - Posts: 233
Does anyone know of a simple way of accomplishing what I am trying to do?
Presently, I use the cross hair tool, after initially placing the line, to check price level. However, that is a cumbersome procedure that often requires several tries before I get it just right.
Thanks much for any help.
[2013-12-03 03:56:19]
You just need to look at the Tool Values window or the Compact Tool Values window as you draw the line:
http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#ViewingToolandChartData
It will show the Y axis value of the line as you draw it.
