Date/Time: Sat, 01 Feb 2025 03:47:11 +0000
OHLC for Weekly, Monthly, and yearly bars
View Count: 1085
[2019-06-24 15:10:30] |
User834905 - Posts: 35 |
How can I get the OHLC data points for the current bar from Weekly, Monthly, and yearly charts? I want to overlay the result on another chart. I see I can use the study 'Previous Bar Close' to get the data points for the previous bar. |
[2019-06-24 23:52:05] |
There are a few options available, but probably the easiest would be to add 4 versions of the Spreadsheet Formula study, where you set the Number of Bars to Calculate to 1. Then enter H, L, O, and C for the formulas into each study respectively. The best way to then visualize the information is to set the Draw Style to Dash and the colors different for each study. Then you can apply your Study/Price Overlay 4 times to get these onto the chart you want. Refer to the following for the Spreadsheet Formula study: Spreadsheet Formula And refer to the following for changing the subgraph color and the section after it for the Draw Style: Chart Studies: Subgraphs Tab >> Color And refer to the following for the Study/Price Overlay study: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
