Date/Time: Sat, 01 Feb 2025 06:45:34 +0000
Crosshair Tool Horizontal Line Vanishes
View Count: 758
[2019-06-24 07:57:39] |
CMG - Posts: 179 |
Hi There, When adding study "Percent Change Since Open" to a chart and displaying this study in region 1 of the chart, the horizontal axis of the Crosshair tool vanishes. Is there a way to have the complete Crosshair as per the above described study use and setting? Thanks |
[2019-06-27 14:10:33] |
This does not make technical sense. Does this occur when you are using the Chart Values tool within that specific chart?
[2019-06-27 23:02:56] |
CMG - Posts: 179 |
Hi, It occurs with and without using the Chart Values toll. I narrowed down to the following settings: 1. Line on Open chart Studies: A) Percent Change Since Open: With the following settings: i)Display as main price chart ii) Value Format: Percent iii) Start Time: Trading day start Time iv) Imput Data: Open v) Multiplier: 1 Chart uploaded for you review. Thanks |
