Date/Time: Sat, 01 Feb 2025 04:11:17 +0000
v.'s 1937,1938,1939 - Dsiplay Study Name
View Count: 766
[2019-06-24 03:10:51] |
KXRCap - Posts: 64 |
These versions Display Study Subgraph Name even when unchecked. This is consistent across these versions.
[2019-06-24 03:12:01] |
Yes that is the correct behavior. There is another option to hide the Subgraphs on the Subgraphs of the Study Settings window.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-24 03:13:20
[2019-06-24 07:01:33] |
caligola - Posts: 116 |
I have noticed the same Before version 1937 in was enough to uncheck Display Study Name, Subgraph Names and Subgraph Values - Global https://www.sierrachart.com/index.php?page=doc/ChartStudies.html&CAID=default#DisplayStudyNameSubgraphNameAndValues_Global Now I have to uncheck also Display Study Name So my understanding is that the global option ( Display Study Name, Subgraph Names and Subgraph Values - Global ) does not override anymore the specific option ( Display Study Name ) Date Time Of Last Edit: 2019-06-24 07:26:36
[2019-06-24 12:34:53] |
Update to version 1939. The name of that option has now been correctly labeled to indicate it only applies to Subgraphs.
