Date/Time: Sat, 01 Feb 2025 03:53:29 +0000
Simulation trades - where are they executed
View Count: 686
[2019-06-22 19:16:19] |
User459170 - Posts: 262 |
Where are the simulation trades executed? If on server, on whose server? Thank you.
[2019-06-23 02:53:26] |
If you are using Trade Simulation Mode: Trade Simulation The simulation is within Sierra Chart. Otherwise it is external. If you are using the Simulated Futures Trading Service: Simulated Futures Trading Service then it is a Sierra Chart server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
