Date/Time: Fri, 18 Apr 2025 16:33:07 +0000
Accummulated Delta in the ZigZag Study
View Count: 2791
[2019-06-21 17:38:44] |
Gustavo - Posts: 74 |
Please refer to the attached image for additional clarification.... Can the color of the text made to match the sign of the accumulated delta when we have the case of an upthrust with a negative delta and vice a versa? In the attached image, as an example, the text for the accumulated delta would be red instead of green when the delta is "negative on an upthrust;" and vice a versa. |
[2019-06-23 20:00:08] |
John - SC Support - Posts: 39356 |
Yes, this can be done, but requires using 4 different Color Bar Based on Alert Condition studies. We have put together a study collection that contains the basis for what you are looking for. You will find the study collection here: https://www.sierrachart.com/AdditionalFiles/ZigZagAccVolumeColorByPosNeg.StdyCollct Follow the instructions here for how to use this study collection: How to Use an Advanced Custom Study or a Study Collection: How to Use a Study Collection For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-24 11:53:02] |
This is perfect! Thanks so much.
[2020-08-18 21:34:45] |
User240019 - Posts: 112 |
Hello, thank you for this study collection. I've updated it to reflect a diamond rather than the text, but what I've noted in the behavior is that only a single study will show the diamond. The oppososing colar bar on alert condition will not show the diamond. IN particular, I want to show when positive delta occurs on the bottom and when negative occurs on the top. But, as I've said, only one study will show. Additionally the scale functions are very sensitive. In fact, when I changed it, the chart immediately redraw the scale and I had to bring it back to the price. What must I change to fix this? |
![]() Attachment Deleted. |
[2020-08-18 22:26:34] |
Hi, I tried this on another chart and this is what appears to be happenning when you change it to a drawing.
[2023-01-17 19:09:08] |
User183456 - Posts: 4 |
Is this study collection (ZigZagAccVolumeColorByPosNeg.StdyCollct) still working? for me this is just an empty collection displaying an clean chart with 0 studies.
[2023-01-17 22:05:46] |
We have updated the Study Collection of ZigZagAccVolumeColorByPosNeg.StdyCollct in the Additional Files page of the website for the current version of software. You can access the file directly here: https://www.sierrachart.com/AdditionalFiles/ZigZagAccVolumeColorByPosNeg.StdyCollct For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
