Date/Time: Sat, 01 Feb 2025 03:47:19 +0000
Watch List Menu Dropdown Font Size
View Count: 600
[2019-06-21 16:58:29] |
jaxscott1 - Posts: 24 |
I'm trying to figure out how to make the font on this dropdown larger to no avail. Anybody have any guidance on which setting to use?
[2019-06-22 02:50:10] |
In the case of a drop-down list the font size is controlled by the Windows operating system.
