Date/Time: Sat, 01 Feb 2025 03:59:00 +0000
Stop Orderes
View Count: 708
[2019-06-21 16:04:47] |
John Ara - Posts: 125 |
Please help me know how I can get into trades myself not by preset orders but to get out of my trades by preset attached orders. Thank you. |
[2019-06-22 02:52:09] |
Here is the relevant documentation for that: Attached Orders Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-23 15:57:03] |
Thank you for sending these documents. To be more specific, please let me know if I can have a child order with bigger quantity than the parent order quantity. For example, when I go long with 3 contract, I need an automatic sell stop be ordered with 6 contracts so when market goes against me and my 3 longs are sold with stop order, I want another 3 contracts gets sold for me at the same time. Something like setting an automatic reverse order. I can not do this now, It shows a message that child order must have a quantity bigger than parent order. Thank you. |
[2019-06-23 17:56:39] |
This is not directly supported as you are looking for. In this case what you need to do is enter a separate order at the same price as the Stop order. And you would probably be interested in using a Triggered Limit order which would be safer to reenter the market after there is some retracement of price: Order Types: Triggered Limit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-23 17:56:47
[2019-06-24 00:40:52] |
Also, please let me know how I may add up quantities in a column in DOM like total volumw column or P/L column. It shows the total of every price but I need the sum of all at a time. Thank you. |
