Date/Time: Sat, 01 Feb 2025 04:00:45 +0000
Regarding bar processing increment while auto backtest
View Count: 835
[2019-06-21 11:58:09]
User479048 - Posts: 19
I was backtesting and when i used 250 value for bar processing increment i got different result while when i change the value i got different result in trade statistics.
What does it actually mean , for eg: we say 250 then i read in sierra it says it process 250 bars once at a time.
What is the best practice for this, should i keep the default value i.e 250?
how does it work for live trading?
[2019-06-23 15:10:54]
What version of Sierra Chart are you running? Make sure you are running the current version of Sierra Chart. And is this a multiple chart back test you are doing? Or are you just replaying one chart.
The processing of data during live trading is different. This is explained in more detail here:
Auto Trade System Back Testing: Differences Between Back Testing and Real-Time Auto Trade System Evaluation
