Date/Time: Sat, 01 Feb 2025 03:51:18 +0000
autotrade system replay backtest
View Count: 664
[2019-06-21 10:21:53]
User28317 - Posts: 149
I have been testing my models with YM going back 3 years with no problem.
I find that my latest test will only go back a month.
I cleared the trade simulations
I shut the application down and rebooted
I went into the chart and tried to force the date
i have the futures chart set to continuous futures contract-volume based rollover
I set the start time to 2016-01-01
under chart settings I set the days to 1000
Still no luck in getting the start date back.
Date Time Of Last Edit: 2019-06-21 10:49:18
[2019-06-21 12:22:36]
Solved.
it turns out that that particular chart was not updated to the new data service. So all of my efforts were wasted.
Sorry to bother you.
[2019-06-21 13:44:48]
Ok, that makes sense because you really should not have had trouble with this.
How is everything going with the new SC order routing service and the exchange data feed? Or too soon to tell any difference.
Date Time Of Last Edit: 2019-06-21 13:45:50
[2019-06-21 13:53:27]
VERY HAPPY WITH SC ROUTING.
FAST EXECUTION AND APPEARS MORE SEAMLESS WHILE TESTING THEN WITH THE PREVIOUS PROVIDER.
[2019-06-21 15:38:36]
Definitely CME execution is fast when you are using the CME Aurora data center server (Server 2) as the primary server.
As far as testing goes you should not notice any difference but if everything is better with that, that is good.
Date Time Of Last Edit: 2019-06-21 15:39:02
