Date/Time: Sat, 01 Feb 2025 03:49:03 +0000
Floating Control Bar - Same size for Control Bar Buttons
View Count: 754
[2019-06-21 07:34:04]
caligola - Posts: 116
I have a chartbook with a Floating Control Bar and Use Same size for Control Bar Buttons checked.
Every time that I open that chartbook I have to check again the Use Same size for Control Bar Buttons option.
The same apply viceversa: in a chartbook with a Floating Control Bar and Use Same size for Control Bar Buttons unchecked, every time that I open that chartbook I have to uncheck again the Use Same size for Control Bar Buttons option.
It seems like the Use Same size for Control Bar Buttons option can't be saved in a Floating Control Bar
I'm running the latest SC 1938, the same apply to SC 1931 and 1932
Thank You
[2019-06-21 15:10:47]
We will check on this.
[2019-06-21 17:53:10]
Merlin - Posts: 83
+1 - I've been having the same problem.
[2019-06-21 18:19:25]
Marmany - Posts: 308
I have an intermittent issue on a sub instance where sometimes on start up width of all buttons in a Control Bar is increased to that of the widest. Closing that instance and re-opening clears the issue. "Use Same size for Control Bar Buttons" is unchecked and Control bar is not floating.
Maybe unrelated to this thread but brought it to your attention in case it helps with the troubleshooting.
Will post a screen shot next time issue occurs.
Running v 1932 but also occurred on a previous version.
[2019-06-23 05:48:55]
We have released version 1939 to correct the original described issue. Let us know if post #4 is still an issue.
