Date/Time: Tue, 04 Nov 2025 09:37:43 +0000
(ACSIL) How do I trigger a subgraph when exiting a trade from an attached order?
View Count: 848
[2019-06-21 01:28:43]
Tom Hanks - Posts: 20
Triggering a subgraph to indicate where you entered a position is straight forward, but I'm not sure what the best way to achieve this is for exiting when using attached orders.
My guess is to do a check like this on every bar:
sc.GetOrderByOrderID for all attached stop and target orders (order ids saved with persistent variables) and then use s_SCTradeOrder::OrderStatusCode to check if the orders are SCT_OSC_FILLED. If one of my exit orders = SCT_OSC_FILLED then draw a subgraph indicating an exit as I would on entry orders.
Would this be the best way or is there something easier?
Thanks!!
[2019-06-21 15:23:15]
ForgivingComputers.com - Posts: 1153
After you determine it is filled set the subgraph to the AvgFillPrice of the trade order.
[2019-06-21 15:40:36]
We think the better way to do this, is to get the most recent fills with this function:
Automated Trading From an Advanced Custom Study: sc.GetOrderFillEntry()
And then looking to see if the previously saved Internal Order IDs have filled. Just specify the highest available fill index when getting the fills.
