Date/Time: Sun, 24 Nov 2024 19:06:38 +0000
Columns K, L, M & N
View Count: 1259
[2013-11-29 17:17:05]
Richard Reyes - Posts: 98
In using Columns K, L, M & N for automated trading strategy's, as I understand it, Columns K and N and Columns L and N work together. If Columns K and N are showing a "FALSE" signal in Cell 3, should then Columns L and M be showing a "TRUE" signal in Cell 3 or visa versa and so on and so on for the following cells? Would this be a way of knowing that your Excel formulas are correct with regards to your trading strategy? Many Thanks
[2013-12-03 03:59:00]
For a description of how these Order Action columns work, refer to this section here:
http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#ColumnSignalTypes
What each of the columns will be showing from row to row depends upon your trading logic. There is no definite answer this.
Date Time Of Last Edit: 2013-12-03 03:59:56
