Date/Time: Sat, 01 Feb 2025 03:51:04 +0000
number of trades
View Count: 1366
[2019-06-19 23:24:55] |
bskogz12 - Posts: 38 |
I have number of trades study on my charts, whats the easiest way to change this so its like volume, green on up and red on down...i tried the color bar alert but it didnt seem to work.
[2019-06-20 19:36:27] |
John - SC Support - Posts: 37656 |
Just use the Subgraph Auto-Coloring option for Same as Base Graph, and it will color the Number of Trades in the same way as the Volume study does by default. Refer to the setting here: Chart Studies: Same As Base Graph Note that you may need to change the secondary color to be red, as it is a darker green by default. Refer to the information here for how to change the colors: Chart Studies: Subgraphs Tab >> Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
