Date/Time: Sat, 01 Feb 2025 03:53:23 +0000
How Can I Open More Than One Chart Value WIndow?
View Count: 629
[2019-06-19 21:15:47]
User254376 - Posts: 1
How can I open more than one "Chart Value Window" and have them represent data from separate sources simultaneously?
For instance,
If I click on the 1 minute chart, the Chart Value Window reflects only the 1 minute chart.
And when I go to click the 1 HR chart, the Chart Value Window reflects only the 1 minute chart
I would like top have 1 chart value window for each time chart. Is that possible? And if so how?
Also how can I scale the Chart Value Window without cutting off information?
[2019-06-20 18:37:33]
Only one Chart Values window can be displayed at a time. But you can use multiple instances of Sierra Chart:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
This is not correct. It will update to the active chart. Maybe you are thinking of the Tool Values Window which is different.
You can adjust the font of the Chart Values window:
Graphics Settings: Fonts and Text Appearance
And refer to:
Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line
Date Time Of Last Edit: 2019-06-20 18:38:01
