Date/Time: Thu, 28 Nov 2024 16:35:11 +0000
Download problem
View Count: 897
[2019-06-19 20:18:04]
User927453 - Posts: 2
Dear support,
I am having trouble downloading Sierra on to my new computer. When trying to download, in the process a error message stops the download and is sayiny "Error saving downloaded files to local system. Stopping installation. Check log. Press 'install' to retry. i have searched for frequently answered question and can not find any answered question there. I am using chrome for my internet. i am using windows 10 and my computer has very high specs. Can you please help asap.
Kind regards
Genevieve
[2019-06-20 04:15:27]
Install Sierra Chart using this zip installer:
https://www.sierrachart.com/downloads/ZipFiles/SierraChart1928.zip
Extract the files into C:\SierraChart on your system.
And run Sierra Chart by running the SierraChart_64 executable.
Date Time Of Last Edit: 2019-06-20 04:15:55
[2023-04-18 06:43:59]
Andrej Bábsky - Posts: 3
Halo to evererybody,
I have the same issue, can you help me please.
When trying to download Sierra Chart software for first time, in the process a error message stops the download and is sayiny "Error saving downloaded files to local system. Stopping installation. Check log. Press 'install' to retry." My computer is ok.
This link does not work: https://www.sierrachart.com/downloads/ZipFiles/SierraChart1928.zip
Sincerly,
Andrej
[2023-04-18 15:09:24]
John - SC Support - Posts: 36350
That version you are trying to get from the Zip installer is too old. You can access the files at the following link:
https://www.sierrachart.com/index.php?page=doc/SCZipInstallerList.php
