Date/Time: Sat, 01 Feb 2025 02:00:23 +0000
Highest High/Lowest low Over N Bars - low value display bug
View Count: 864
[2019-06-19 20:14:11] |
whats1thingnow - Posts: 407 |
hi support, this bug has existed for at least a month but i never reported it. please help fix the the display of the 'low' value for study 'Highest High/Lowest low Over N Bars' for whatever reason, there is another value that shows underneath the lowest value on the value scale screenshot: * 331 is the highest high for N bars * -5 is the current price * -304 is the lowest low for N bars * -758 is the random value that's showing underneath the lowest value thanks!!! Date Time Of Last Edit: 2019-06-19 20:15:19
2019-06-19_1311.png / V - Attached On 2019-06-19 20:12:23 UTC - Size: 2.25 KB - 250 views |
[2019-06-20 14:31:00] |
John - SC Support - Posts: 37656 |
We are unable to tell what is happening from that screenshot. Can you please attach a chartbook following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
