Date/Time: Sat, 01 Feb 2025 04:05:28 +0000
SIERRA REAL TIME DATA trying to find the implied spread symbols for OIL and Grains
View Count: 1132
[2019-06-19 14:52:17]
User450179 - Posts: 105
I did a search like it said to in this forum for spread symbols but it only found 1. how do you I get or see the different exchange spread symbols on your real time data feed or where can i see the correct format and manually put in the ones that I want to follow.
THANK YOU. also doing a symbol search like you guys instructed did not get any useable results
CL and wheat
[2019-06-19 18:12:52]
Refer to:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads
[2019-06-19 18:43:54]
again this is exactly what I tried before going to the board. I found this exact link and have followed it to a "T."
all it does is show the MICRO symbols for the futures stock indicies. I wish it worked like your instructions.
can you tell me what I need to do in order to get the rest of the symbols pulled up?
M2k
MES
MNQ
are the only symbols that appear when the "Plus sign" is selected expand
I changed the data services from GAIN/trading to the sc data all services and it did then populate the symbols
however, it shut down my capability to trade and all of my other charts?
how can I use these symbols and trade the EXCHANGE SPREAD?
or can you show the format for the symbols and can we put them in since there are so many combinations?
Frustrating on my end but understand how many different companies and symbols are out there.
thanks
Date Time Of Last Edit: 2019-06-19 18:54:10
[2019-06-20 18:02:06]
I will ask again since the reply did not help me much.
I am paying for real time data and I would like to get the symbols to chart the
exchange implied spreads in CRUDE OIL (NYMEX) and some grains?
how do i add these symbols to my quote board?
and also can I open a DOM from the chart of these implied spread symbols to trade off of?
thanks in advance?
[2019-06-20 18:13:10]
Ok we understand what the problem is now. We should have recognized this earlier.
In order not to create unnecessary confusion for our users when using the different trading services which have no support for the symbol format for spreads from the Sierra Chart Exchange Data Feed for trading, we no longer list those spread symbols and the ability to get listings for them when using those trading services other than with Interactive Brokers.
If this is what you need to do and not just chart these spreads, you need to switch to this service instead of Gain Capital:
Sierra Chart / Trading Technologies Futures Order Routing Service
Could you tell who your introducing broker is?
Date Time Of Last Edit: 2019-06-20 18:14:45
[2019-06-20 18:18:14]
Thank you and you guys have a lot more to deal with overall than just one customer who wants just his particular needs met. thank you for your
very quick reply and solution to my problem
have a great day
oops.. yes my IB is stage 5
Date Time Of Last Edit: 2019-06-20 18:19:30
[2019-06-20 18:55:53]
Ok, being you are using the Sierra Chart Exchange Data Feed already, we think it is a good choice to migrate over to this TT based order routing. It is not going to cost anything more. And Stage 5 does support it.
[2019-06-20 19:00:17]
I would have to agree completely! thank you
