Date/Time: Sat, 01 Feb 2025 00:58:07 +0000
Error message - chart not appear
View Count: 613
[2019-06-19 12:37:35] |
User359749 - Posts: 3 |
Hello, I received the following error message: "Error setting System Date-Time. Windows error code 1314: A required privilege is not held by the client. | 2019-06-19 08:31:39.178 * Chart is not appearing. Thank you for the assistance |
[2019-06-19 14:28:50] |
This is unrelated. In regards to the problem with the chart not appearing follow the instructions below: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
