Date/Time: Sun, 20 Sep 2026 13:04:55 +0000
[Programming Help] - ACSIL Interface Members - Functions
View Count: 3750
[2019-06-18 21:53:20]
User630795 - Posts: 93
I am trying to modify KnowxvilleDivergence study to find divergence using StochasticMomentumIndicator study instead of RSI.
It uses sc.RSI(....) function but according to your documentation, StochasticMomentumIndicator is not available for that.
First of all, can you confirm if that is true and also if there is another way. I am attaching part of the KnoxvilleDivergence study that calls RSI study to find divergence:
sc.RSI(sc.BaseDataIn[inp_rsi_input.GetInputDataIndex()], graph_rsi, inp_rsi_movavg.GetMovAvgType(), inp_rsi_length.GetInt());
[2019-06-18 22:09:29]
We do not understand the question.
[2019-06-18 22:17:12]
I don't understand what you don't understand.
according to your list (link provided), SMI is not callable.
It is not listed.
[2019-06-18 22:18:48]
Ackin - Posts: 1865
StochasticMomentumIndicator is study in file studies8.cpp
SCSFExport scsf_StochasticMomentumIndicator
"sc.RSI(sc.BaseDataIn[inp_rsi_input.GetInputDataIndex()], graph_rsi, inp_rsi_movavg.GetMovAvgType(), inp_rsi_length.GetInt());"
output Stochastic "SMI" as same as "graph_rsi" from RSI....
[2019-06-18 22:23:53]
i know where the code for SMI is.
i want to be able to refer to it (or call it?) from KnoxvilleDivergence.cpp like "sc.StochcasticMomentumIndicator(sc.BaseDataIn........)" but it is not listed on your list ACSIL Interface Members - Functions
[2019-06-18 22:27:44]
Ackin - Posts: 1865
I understand, but there isn't for this any function. You can copy the block code from file8 ....
I'll do this, it's faster for me then write about it ...
give me one hour...
Date Time Of Last Edit: 2019-06-18 23:20:35
[2019-06-18 23:10:52]
Ackin - Posts: 1865
Try this file ... 64-bit
Date Time Of Last Edit: 2019-06-18 23:21:06
attachmentKnoxville Divergence_64.dll - Attached On 2019-06-18 23:10:33 UTC - Size: 115 KB - 544 views
[2019-06-18 23:39:45]
may i ask what you did with it?
thanks.
[2019-06-18 23:42:33]
Ackin - Posts: 1865
Is it what you want? Works?
[2019-06-18 23:44:12]
i want to use stochastic momentum indicator not just stochastic.
did you use stochastic momentum indicator?
may i see the source code?
it does not work properly for stochastic momentum indicator (SMI)
[2019-06-19 00:25:01]
Ackin - Posts: 1865
Sure..
RSI part is replaced with:
      SCFloatArrayRef TempLowest = SMI.Arrays[0];
      SCFloatArrayRef TempHighest = SMI.Arrays[1];
      SCFloatArrayRef TempRelDiff = SMI.Arrays[2];
      SCFloatArrayRef TempDiff = SMI.Arrays[3];
      SCFloatArrayRef TempAvgRelMA = SMI.Arrays[4];
      SCFloatArrayRef TempAvgRel = SMI.Arrays[5];
      SCFloatArrayRef TempAvgDiffMA = SMI.Arrays[6];
      SCFloatArrayRef TempAvgDiff = SMI.Arrays[7];
      sc.Lowest(sc.Low, TempLowest, PercentKLength.GetInt());
      sc.Highest(sc.High, TempHighest, PercentKLength.GetInt());
      TempRelDiff[sc.Index] = sc.Close[sc.Index] - (TempHighest[sc.Index] + TempLowest[sc.Index]) / 2.0f;
      TempDiff[sc.Index] = TempHighest[sc.Index] - TempLowest[sc.Index];
      sc.ExponentialMovAvg(TempRelDiff, TempAvgRelMA, PercentDLength.GetInt());
      sc.ExponentialMovAvg(TempAvgRelMA, TempAvgRel, PercentDLength.GetInt());
      sc.ExponentialMovAvg(TempDiff, TempAvgDiffMA, PercentDLength.GetInt());
      sc.ExponentialMovAvg(TempAvgDiffMA, TempAvgDiff, PercentDLength.GetInt());
      if (TempAvgDiff[sc.Index] != 0.0f)
        SMI[sc.Index] = TempAvgRel[sc.Index] / (TempAvgDiff[sc.Index] / 2.0f) * 100.0f;
      else
        SMI[sc.Index] = 0.0f;
If it doesn't work properly, so It's issue this study (I don't use divergence, but I know it had a few limitations).
Date Time Of Last Edit: 2019-06-19 00:26:32
[2019-06-19 02:17:35]
Yes, I use it with other studies for confirmation.
I've used divergence studies for another platform for a long time.
If you don't mind, can I have the entire code?
I'd like to tweak it for my liking.
Thank you again.
[2019-06-20 15:19:10]
can you email me the source code of the entire study?
thanks.
[2019-06-20 18:28:11]
Ackin - Posts: 1865
I dont know your email...
Sign up for our forum, we can improve this or similar study to be useful to everyone and was universal.
more info about our work
Ackin's indicators (SCH users requests for studies) - Update list | Post: 182033
Date Time Of Last Edit: 2019-09-06 17:04:28
