Date/Time: Sun, 24 Nov 2024 20:07:27 +0000
v 1054 -
View Count: 1387
[2013-11-29 00:41:00]
Kiwi - Posts: 375
The line int Size = sc.GetTradeListSize(); is causing this error:
Warning: The Custom DLL study "KiEx._scsf_ControlEntries" has just caused a CPU exception. | 2013-11-29 10:37:13
Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from your chart and restart Sierra Chart. | 2013-11-29 10:37:13
The chart has no history of live orders and gives the error when there were no sim orders but also after I'd created a couple in replay.
SCSFExport _scsf_ControlEntries(SCStudyGraphRef sc)
SCSubgraphRef o0 = sc.Subgraph[0], o1 = sc.Subgraph[1],
o2 = sc.Subgraph[2], o3 = sc.Subgraph[3],
o4 = sc.Subgraph[4], o5 = sc.Subgraph[5];
if (sc.SetDefaults)
sc.GraphName=" ";
sc.StudyDescription="Expt";
sc.Subgraph[0].Name="o1 ";
sc.Subgraph[1].Name="o2 ";
sc.Subgraph[2].Name="o3 ";
sc.Subgraph[3].Name="o3 ";
sc.Subgraph[4].Name="o4 ";
sc.Subgraph[5].Name="o5 ";
sc.GraphRegion=0;
sc.ScaleRangeType = SCALE_SAMEASREGION;
sc.CalculationPrecedence = VERY_LOW_PREC_LEVEL;
sc.FreeDLL=1;
bool killOrders = false;
int as = sc.ArraySize - 1;
  std::vector <s_ACSTrade> TradesList;
  s_ACSTrade TradeEntry;
  //for(int i = 0; i < Size;i++)
    //if(sc.GetTradeListEntry(i, TradeEntry))
      //TradesList.push_back(TradeEntry);
  //for (unsigned int i = 0, ti = TradesList.size() - 1; ti >= 0 ; i++, ti--)
//o4[as-i] = TradesList[ti].ClosedProfitLoss;
sc1054, wine, debian jessie
[2013-11-29 00:50:34]
Kiwi - Posts: 375
I basically just copied the example from the ACSIL trade page and then removed things to try to isolate what was causing the exception.
The error occurs when the study is added to the chart or when the chartbook is opened.
Edit: Note that although the message is still posted I am now using the code and it seems to work properly.
Date Time Of Last Edit: 2013-11-29 05:22:55
[2013-11-29 18:00:39]
This should be fixed in the next release. However, the problem is you are not returning at the bottom of the sc.SetDefaults code block.
[2013-11-29 21:35:53]
Kiwi - Posts: 375
Thanks. Been cutting and pasting a lot of old code and obviously missed that this time.
