Date/Time: Sat, 01 Feb 2025 02:05:28 +0000
Where are the Lifo Fifo settings
View Count: 2160
[2019-06-18 14:42:01] |
User360283 - Posts: 508 |
thanks
[2019-06-18 19:40:34] |
Why does LLifo or Fifo not come up on search?
[2019-06-19 19:12:44] |
You need to update to the latest version: Software Download: Fast Update In the case of the Trade Activity Log, there is a menu command for LIFO: Trade Activity Log: Menu Commands In the case of a chart, refer to this setting: Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-19 19:13:05
