Date/Time: Sat, 01 Feb 2025 00:51:02 +0000
Problem with Real Time Quotes
View Count: 593
[2019-06-18 11:08:49] |
User182617 - Posts: 3 |
Hello , I don't have problem with the data on the DOM.My problem is that the data on the sierra chart ,Although I'm connecting to a live server the data don't run according to the data on the DOM or they don't run at all. |
[2019-06-18 16:08:24] |
We want you to update to prerelease 1936. Here are instructions: Software Download: Fast Update Make sure you select Help >> Download Prerelease. And then if you still do not receive data, provide a copy of the Message Log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
