Date/Time: Sat, 01 Feb 2025 00:45:03 +0000
Resizing "Custom Window"
View Count: 1203
[2019-06-18 10:17:21] |
User590016 - Posts: 50 |
Hello, Is it possible to resize the high and the width of the custom window containing 3rd party studies because it's hard to read if a have an extended list with long descriptions of studies. Finally the adding of a search function with auto completion would ease the work as well. Thanks Date Time Of Last Edit: 2019-06-18 10:41:27
[2019-06-18 15:21:04] |
We do not know what you are referring to.
[2019-06-18 19:48:13] |
On this screenshot you see the window to add custom studies. But it can cannot be resized and it has no search function. If a study has a description which is long I cannot read it all at full view. The same goes if I have a huge list I have to scroll down and not resize the window. And there is not search function to show just what you type in. |
Attachment Deleted. |
[2019-06-18 20:32:57] |
Ok we see. This window cannot resized but the list of studies does have a horizontal scrollbar.
[2019-06-19 08:21:31] |
I dont like the scroll bar because I have a huge list and I want to be able to resize the window accordingly. Is that possible? |
