Date/Time: Sat, 01 Feb 2025 02:09:06 +0000
over-sized windows
View Count: 638
[2019-06-17 20:55:44]
rizzy - Posts: 13
When i connect my laptop to an external screen all the charts and tools panel are oversized and not properly scaled.
The app runs fine when i use the laptop by itself. not sure how i can fix the scaling issue
Date Time Of Last Edit: 2019-06-17 20:57:11
imagesierra chart.PNG / V - Attached On 2019-06-17 20:52:40 UTC - Size: 60.75 KB - 262 views
imagesierrachart2.PNG / V - Attached On 2019-06-17 20:54:32 UTC - Size: 198.09 KB - 246 views
imagesierra chart.PNG / V - Attached On 2019-06-17 20:57:07 UTC - Size: 107.37 KB - 233 views
[2019-06-17 21:09:00]
You just need to reduce the Chart Text font size and also the Control Bar font size.
Refer to:
Graphics Settings: Fonts and Text Appearance
There is no need to bother with any of those Windows settings.
Date Time Of Last Edit: 2019-06-17 21:09:53
[2019-06-17 21:37:27]
rizzy - Posts: 13
that fixed most of it but the text inside the chart still seems a bit oversized (red and white line # labels), is that adjustable or no?
imagesierra chart.PNG / V - Attached On 2019-06-17 21:36:07 UTC - Size: 91.25 KB - 246 views
[2019-06-17 22:18:24]
You are referring to the Chart Drawing Font. Refer to:
Chart Drawing Tools: Changing the Font Size For Text Displayed with Tool Drawings (Global Chart Drawing Font)
