Date/Time: Sat, 01 Feb 2025 01:45:26 +0000
footprint chart setup
View Count: 959
[2019-06-17 20:07:10] |
User214233 - Posts: 7 |
My footprint chart doesn't display right. Needs assistance in setting it up. Please see screenshot.
footprint.PNG / V - Attached On 2019-06-17 20:06:47 UTC - Size: 49.5 KB - 411 views |
[2019-06-17 21:16:54] |
The first thing you need to do is increase the spacing between the chart bars. Refer to: Working With Charts: Changing Bar Spacing What else do you require? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
