Date/Time: Sat, 01 Feb 2025 02:09:50 +0000
c drive getting full
View Count: 659
[2019-06-17 19:38:55] |
User988578 - Posts: 24 |
hi my c drive is filling up with big files see attachment can i delete these to free up space |
sc mem2.JPG / V - Attached On 2019-06-17 19:36:32 UTC - Size: 25.41 KB - 285 views Attachment Deleted. sc mem 1.JPG / V - Attached On 2019-06-17 19:38:04 UTC - Size: 21.61 KB - 263 views |
[2019-06-17 22:19:04] |
You can delete the Intraday data files for symbols that you no longer need: Chart Data and Chart Data Files: Deleting a Chart Data File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
