Date/Time: Sat, 01 Feb 2025 01:49:05 +0000
Large Lot delta
View Count: 1442
[2019-06-17 17:32:06]
User114021 - Posts: 1
Do you have a study or a way to set up on a line chart the large lot delta, medium lot delta and small lot delta? large lots greater than 100
medium greater than 49 but less than 100
small lot less than 49.
kim
[2019-06-18 01:54:21]
This really is going to require three separate charts and you need to use the Volume filtering for this:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
You can then display this information through Numbers Bars:
Numbers Bars
Or the Numbers Bars Calculated Values study which can be overlaid onto a single chart from the other charts:
Numbers Bars: Displaying Numeric Information Below Numbers Bars
Date Time Of Last Edit: 2019-06-18 01:54:56
