Date/Time: Wed, 27 Nov 2024 22:40:55 +0000
symbol alerts storage location
View Count: 805
[2019-06-17 16:27:13] |
User12089 - Posts: 361 |
symbol alerts (as setup in e.g. the SC Alert Manager) storage location - what is it on the file system e.g. what file?
[2019-06-17 16:35:27] |
These are stored within the Sierra3.cfg file.
[2019-09-25 04:13:27] |
User106180 - Posts: 88 |
Would it possible to have a separate readable Alert Manager file, as opposed to storing them in the Sierra3.cfg file which is not readable? Having such a file would allow descriptive alerts to be sent. For instance, for a specific alert I can set a program/script to be run (Global Settings -> General Settings -> Alerts/General 3) that could pull information out of the Alert Manager file (eg Type, Source, Alert Text), and then send a notification to a phone/computer etc. At the moment numerous alerts/scripts have to be made if I want the notification to contain any information. Thanks. |
