Date/Time: Sat, 01 Feb 2025 01:55:15 +0000
Export Renko bar OHLC info into CSV
View Count: 1442
[2019-06-17 15:48:12] |
User972768 - Posts: 166 |
Hello, Could you please help me with exporting OHLC data from Renko charts? Menu "Edit >> Export bar data to text" file produces CSV file, but it has "incorrect" Open and Close information. I would like to see those "Renko Open" / "Renko Close" data points (that I can observe via Compact Tool Value window) in my CSV file. If you can't replace "standard" Open & Close information, would it be possible to have those "Renko Open" and "Renko Close" data points as 2 extra columns in the export file? Thanks and Best regards |
[2019-06-17 21:13:44] |
You need to add this study to the chart: Renko Visual Open/Close Values And export the bar and study values: Edit Menu: Edit >> Export Bar and Study Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-17 21:28:29] |
Thank you for quick reply
