Date/Time: Wed, 19 Mar 2025 13:41:49 +0000
Day session historical chart
View Count: 1029
[2019-06-17 11:17:12]
User834905 - Posts: 35
How can I display a historical chart for the day session only 09:30 to 16:15 ET?
When I display a day period chart the session times are blanked so I can't specify the time.
[2019-06-17 14:01:09]
This is explained here:
Chart Session Times: Creating Daily Bars with Custom Session Times
[2019-06-17 14:28:24]
Thanks.
Is it also possible to get data points for the following:
Overnight Hi / Lo / mid
Day session mid, open
Previous day session close, hi, lo
[2019-06-17 14:54:00]
Use these particular studies:
High/Low for Time Period - Extended
Daily OHLC
And refer to:
Using the Basic Arithmetic Studies
[2019-06-19 03:14:54]
The instruction you gave (link below) to display the daily bar for the day session have worked fine.
The only issue I have is the historical data for this chart is not complete before September 2018.
I have set the contract to rollover (using date rule) but this did not fix the problem - is there a way to display further back?
I tested this using the CQG symbol ENQU19.
____________________________________________________________________________________________
On a separate topic is it possible to set the date format to DD-MM-YY or DD-MM-YYYY?
[2019-06-19 03:55:27]
Refer to:
[2022-10-25 12:46:58]
User731023 - Posts: 147
Is it not possible to use Historic charts with day time session only?
I prefer not to have use Intraday charts.
[2022-10-25 16:00:16]
John - SC Support - Posts: 38782
It is not possible since you want specific times only.
