Date/Time: Sat, 01 Feb 2025 01:03:28 +0000
Note field lost on fill import
View Count: 596
[2019-06-17 10:41:44] |
uM8137 - Posts: 183 |
In v1935, when I export and then import fills back into the Trade Activity Log, the Note field is lost. 2nd minor bug: If I try to set the Note field to annotate manually the order in a text editor, that can result the fills not loading at all. Silently fails. Ponies for the fill log: a) Allow for clickable URLs in the Note field; b) have double mouse clicks on the fill line re-position the chart to the order location time, to allow quick examination of the trade. |
[2019-06-18 03:54:25] |
We will add support for importing the Note field in the next release. 2nd minor bug: If I try to set the Note field to annotate manually the order in a text editor, that can result the fills not loading at all. Silently fails. This really could not be a bug. There must be some other reason for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-18 03:54:35
