Date/Time: Sat, 01 Feb 2025 01:16:49 +0000
How to fix footprint chart
View Count: 766
[2019-06-17 08:28:10] |
daniel1950 - Posts: 13 |
hello, on footprint how do I simplify the number? For example instead of 50,000 x 150,000 contracts traded, how can I make it 50k x 150k? Thanks.
54asfazdsf.PNG / V - Attached On 2019-06-17 08:27:00 UTC - Size: 322.19 KB - 296 views |
[2019-06-18 19:31:29] |
John - SC Support - Posts: 37656 |
Refer to the Numbers Bars setting Use Large Volume Number Formatting documented here: Numbers Bars: Use Large Volume Number Formatting For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
