Date/Time: Sat, 01 Feb 2025 01:08:27 +0000
Volume Rollover Indications
View Count: 705
[2019-06-17 05:37:16] |
HAB-User115006 - Posts: 38 |
1. Is there a 'Volume Rollover' indication/flag that I can access via ACSIL, WITHOUT the 4 days constraint? So anytime the volume of the next contract is greater than the front month volume, I would like to know, because I would prefer to trade a higher volume instrument even if is for a day, a simple flag in ACSIL is ideal but even a visual on the platform might suffice... 2. On the daily chart set up with volume based continuous contract a line appears with the 'Month year' text, does that also use the 4 day constraint? 3. I know about using continuous contract option which will pop up a message - but that has the 4 day constraint as stated in the documentation Thanks for your help... |
[2019-06-18 01:56:37] |
1. You need to use this functionality and make this determination yourself: ACSIL Programming Concepts: Accessing Current Symbol Data for Other Symbols 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-18 04:41:51] |
2. I will go with the line that appears on Daily chart on vol rollover, works... Thanks |
