Date/Time: Sat, 01 Feb 2025 02:09:34 +0000
Alert for ray drawn on a study
View Count: 935
[2019-06-17 05:13:25] |
TeFLoN - Posts: 2 |
I would like an alert for when a study crosses above or below a ray drawn by me. Example would be if a ray trend line is drawn across multiple highs on a rate of change study and I want to be alerted when that ROC crosses above that ray. Is that possible?
[2019-06-18 03:03:33] |
This is supported. Refer to: Chart Drawing Tools: Chart Drawing Alerts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
