Date/Time: Sat, 12 Sep 2026 12:43:55 +0000
[Programming Help] - Need help with alert conditions.
View Count: 1399
[2019-06-16 17:31:57]
User929084 - Posts: 60
Hi, I'm trying to get alert using Color bar based on alert condition study. I have 3 conditions/ statements for the alert. However when I put all three of them together I don't get any signals, but if I use any combination of just two statements it works. It it that AND can only have 2 statements?
=AND(ID18.SG1[0] > ID18.SG1[-1],ID18.SG1[-1] < ID18.SG1[-2],(ID18.SG1 > ID18.SG2,(ID18.SG1<0))) <== Doesn't work, but that's the desired outcome
=AND(ID18.SG1[0] > ID18.SG1[-1],ID18.SG1[-1] < ID18.SG1[-2],(ID18.SG1<0)) <== Works
=AND(ID18.SG1[0] > ID18.SG1[-1],ID18.SG1[-1] < ID18.SG1[-2],(ID18.SG1 > ID18.SG2)) <== Works
I want to get a signal when MACD line crosses above MA of MACD, then MACD changes slope, all while MACD is still below 0 line.
Should I use another study for that or is my code just off a bit.
I attached img to clarify what I want to achieve.
Thank you.
image3alertconditions.png / V - Attached On 2019-06-16 17:27:52 UTC - Size: 2.08 KB - 405 views
[2019-06-17 18:14:37]
gayer2428 - Posts: 99
I don't understand the rationale for your use of parentheses in the first alert condition. As I see it, you just need one open parenthesis and a close parenthesis. It should work. See below.
=AND(ID18.SG1[0] > ID18.SG1[-1],ID18.SG1[-1] < ID18.SG1[-2], ID18.SG1 > ID18.SG2, ID18.SG1<0)
[2019-06-17 18:46:33]
That works. I don't have any coding experience, and I'm just starting with sierra chart and alerts. I learn as I go and dig deeper into capabilities of sierra chart.
Thank you.
