Date/Time: Mon, 03 Mar 2025 15:08:59 +0000
SC real time exchenge data feed
View Count: 1015
[2019-06-16 08:37:48]
AndreyPoroshin - Posts: 105
Having connected the real-time data exchange channel from the Sierra Chart, can I send orders to the exchange through the Sierra Chart and not having a trading account with a broker? There is a possibility? the fact is that I try to find the fastest exchange of orders with the exchange in various ways
[2019-06-16 12:50:57]
You definitely need to have a trading account through a clearing firm which is a member of the exchange. There is not another possibility.
If you are looking for the fastest order routing to the CME, this will be the service to use:
Sierra Chart / Trading Technologies Futures Order Routing Service
[2019-06-16 15:15:52]
1. Did I understand correctly that for one transaction, which includes one purchase and later one sale, I will have to pay $ 20? If this is so, then at the present time it is not profitable for me, I will see how things go, if it is profitable, it will be possible to try.
2. What time does it take for me to complete a transaction, how can I find out and track it? my broker is amp.
Am I right that this is how I will write ?: I give the order in the SC platform, to the AMP broker for the purchase. Ping with ampclearing .com occurs from my computer for 200ms. Then the broker gives my order to the exchange for? milliseconds (maybe 100) In total, my transaction takes about 300 milliseconds?
3. Is the platform detailed information on the time of the transaction before the broker and after it?
4. I'm scared that ping with ampclearing .com -200ms and for example with ninjatrader.com only 2ms. What should I do to reduce the delay?
[2019-06-17 03:44:09]
1. No this is not correct. If you do decide to use the Sierra Chart Order Routing service it is .10 USD per side per contract. This is in addition to any commissions that your broker charges.
2. The orders are sent to TT which then sends them to the exchange. Your broker does not get involved in any order routing.
3. The broker is not involved in order routing.
4. That method of measurement is not accurate.
Date Time Of Last Edit: 2019-06-17 03:44:18
[2019-06-17 05:38:28]
Thanks for the clarification, but this is exactly what TT routing is about, it is very expensive for short transactions. What about other data channels, if not TT? I use CQG via AMP. How does routing work in my case? Does the broker participate in order routing?
[2019-06-17 08:20:33]
1. How in the platform can you see the delay between sending the order and execution?
2. To reduce the delay, which function is better to use, CQG FIX or CQG WEB API?
3. I connected the Sierra Chart from an AMP broker, for free. Does this mean that it can give a delay between sending and executing an order? If I start using a paid subscription directly in the Sierra Chart, will there be a speed advantage?
[2019-06-17 14:51:37]
1. You can look at the timestamps in the Trade Activity Log with each order activity line:
Trade Activity Log
They do include the true milliseconds.
2. We do not know the answer to this. We cannot know that. You have to do your own testing.
3. A direct Sierra Chart account does not change order routing speed.
Date Time Of Last Edit: 2019-06-17 14:52:01
