Date/Time: Sat, 01 Feb 2025 00:52:27 +0000
split profiles
View Count: 1624
[2019-06-14 16:24:08] |
User758506 - Posts: 9 |
hello Does exist a possibility to split automatically the profiles to obtain balanced profiles ? I saw that with ninja trader. It will be very useful to can do this thank you very much for your help !!! |
[2019-06-14 17:08:13] |
Are you referring to splitting of TPO Profiles? You can do this. Refer to: Time Price Opportunity (TPO) Profile Charts: Splitting and Merging TPO Profiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-18 08:56:59] |
hello Does exist a possibility to split automatically the profiles to obtain balanced profiles ? I saw that with ninja trader. It will be very useful to can do this thank you very much for your help !!! I just find to do it manually and it is noy very accurate |
[2019-06-18 16:07:03] |
What is the basis of automatically splitting a TPO Profile? How is the time determined where to do the split?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-06-18 16:07:18
